Briggs intek carb
aau10
The main jets came out while cleaning (Briggs carb #791230). One has what appears to be 113 on it and the other one has 115 on it. Can anyone tell me the pairing to the correct cylinder? Thanks in advance for any help.
motoman
aa, This is a long shot and to let you know the forum tries...In the good ole days on foreign iron a 113/117 might have meant approx 1/10 th of a mm or .1 x .039" which could be the hole dia to feed gas to the inrushing airstream. If this could be then I would not worry about interchanging since the difference is slight. Of course I may be simply be wrong. If you look through the holes I doubt you can tell the diff. By now you are probably up and running.:laughing::
