crobbins175
- Feb 3, 2024
- 1
- 6
I have an MTD rider with a 25 hp Briggs. Mower was running fine. At the end of last season I replaced the main drive belt. First start attempt after belt replacement resulted in a back fire. Second attempt started up fine.
Drove tge mower to verify the belt was good to go. Parked the mower and not will will not start.
I have verified spark, changed plugs, verified fuel is reaching the carb and looked for flywheel sheer issue. All looks good. Will not even fire when starting fluid is sprayed into the air intake while cranking.
.I'm stumped.. the fuel cut off solenoid is working. I have noticed the fuel blown is dry after trying to start.
Open to thoughts and ideas.
Thanks
Thanks
