briggs engine with no throttle
cposten
hey i have a 675 series briggs from a pressure washer that im hoping to use on a different project. the carb on it has no throttle and i need to be able to throttle it when its mounted. can i just buy another carb with a throttle that has the same mount holes or will this not work and ruin the engine? thanks for your time.
mechanic mark
Post model xxxxxx, type xxxx, trim xx from engine.
