I have a Coleman 5500 Watt generator that I bought about 15 years ago. I usually start it up and let it run for 10 minutes every 7 or 8 weeks...in case we lose power out here in the boondocks. Yesterday, I couldn't get it started no matter how many times I pulled the cord. It appears to have spark...I installed a new plug, and hooked up a spark tester, which showed "fire", but I don't think it is getting any fuel...the plug stays dry no matter how much I choke it and pull the rope. I suspect that I'm going to have to go into the carburetor.
The engine is a B&S Model 19E412, Type 010701, 10HP.
if anyone has any ideas on things to check, and try, before I dismantle the carb, or tips on working on the carb, I would appreciate it. I will tackle this project over the weekend.
