motormonkey
- Nov 1, 2014
- 1
- 11
Hello!
First of all I want to say this place is great. been reading for a long time but just signed up.
Ok so... Here's a little story on the background of the issue...
I was asked to fix a lawnmower with a B&S 500 Series (Model # 10T502) on it.
When trying to start it by pulling the recoil it wouldn't even fire and there was a knocking sound in the crankcase.
I removed the fuel tank and drained the oil. I removed the blade and took the motor off the frame and set it up on a motor stand to work on it.
upon removing the head I found a stuck intake valve, lots of carbon on the piston head and on the valves and head but the cylinder walls were in awesome shape actually.
I then split the crankcase because there was no way to un-stick the valve and I needed to work the valves over, clean them up etc.
After removing the camshaft, and removing the valve lifters I could access the bottom of the stuck valve with a very large screwdriver and pry it straight up after removing the valve spring retainer.
I pried the valve up and finally was able to remove it and clean and sand the valves, valve seats and I cleaned the valve stems very lightly with very fine grit sandpaper.
Unfortunately I didn't have a valve lapping tool or compound to to it with so I sanded the valves and valve seats with extra fine sandpaper(500 - 1000 grit) until they seated beautifully. cleaned down the valve guides etc. the valves were working beautifully with just a SLIGHT play in the valves ( and rightly so due to the age, wear and lack of oil changes in the mower).
after that I reassembled the valves, put the springs and retainers back on, the valve lifters in and the Camshaft back in and set my timing marks dead on with cam and crank. (doubled checked my timing by the way the valves moved at TDC on exhaust stroke.)
Then I put a new head gasket on, a little Red Grease (High-Temp) to help protect the head gasket from the heat and reassembled the mower.
I did the old "thumb-Check" for compression covering the spark plug hole with my thumb and it had normal compression. (obviously my thumb can't read psi but you get a feel for it)
put the plug back in, Filled the Oil to correct level, fresh fuel etc,.
primed the carb with 3 squirts from it's PulsaJet carb and it started right up on the 2nd Pull.
It purred like a kitten, I mowed with it for a little bit... then I let go of the bail handle to kill it then I immediately started it back up with 1 pull.
then... I shut it off and came back to it about 15 - 20 minutes later I came back... and.... it wouldn't start.... it had that knock sound of the Camshaft turning but not able to lift 1 or more valves...
I proceeded to remove the valve spring access cover. (took the plug out) and had someone pull the mower rope.. and sure enough.. the valves were not moving.... ( I could move the exhaust valve with a screwdriver no problem... but the intake valve is apparently stuck again.
SO.. I am guessing.. the Camshaft is bent from before.
the cam would about have to be bent for it to be able to turn over if the valves aren't moving.. other wise it would be seized if the cam was straight wouldn't it?
Can someone please give me some insight into why this would stick like this again, so quick, after purring like a kitten. I know I have to tear it down again but some advice.. or moral support would be wonderful.
Many Thanks in Advance.
