I would remove the valve cover and check that push rods are in place and functioning properly, valves are operating and pay particular attention to how much each valve is moving, they should be equal. These engines have a history of camshaft failure. The Intake valve should make a final slight move to fully closed well into the compression stroke. Avoid holding starter engaged longer than 5 seconds without a rest, I prefer no longer than 3 seconds.
I can send you a Service Manual and Valve Adjustment Instructions which include a test for compression release function IF you like. Address below, put in proper format and remind me engine model number and what you want.
Walt Conner
wconner5 at frontier dot com
