Briggs 28Q700 - Flywheel issues....
Apologies for not having the exact type #.....however my problems are 'general'.
Older snapper lawn tractor 155LTH 42BBV (15.5hp B&S horizontal engine),.....solenoid and starter died. Diagnosed with meter.
Replaced starter and solenoid. Now passes proper current..etc.
Ring gear (plastic) had a LOT of teeth missing so I am attempting to replace it with the new aluminum gear.
Issues:
1 - Cannot get flywheel off. Used puller, broke bolts,...used puller some more. Used knock tool hitting it with hammer with prybar underneath..etc. Currently I am spraying it daily with PB Blaster and hoping for some magic to happen.
2 - And this is where my memory is sketchy. I feel like I was previously able to rotate the flywheel by hand endlessly,...meaning 360deg....720deg....it would continue to rotate.
NOW...it seems to rotate only about 350 +/- degrees before it 'hits' something. I can feel/hear compression...etc. The plug is still in,....but this definately is like a 'clunk' when it reaches its rotational limit.....I can rotate back and forth no problem....but simply not endlessly.
I am not sure if this is normal. Something tells me this is bad. Dropped a magnet maybe?
I have not 'beaten' on the flywheel or crank with a 10lb hammer at all....in fact I have been very careful not to use the 'hammer' approach much at all and haven't hit the flywheel itself with anything other than a rubber mallet (and not that hard either).
Any insight? Advice? Thoughts?
Thanks!
Issues:
Thanks!
