TiIngot
- Sep 9, 2022
- 8
- 34
Running on one cylinder with both sides getting spark and fuel. When running the cylinder opposite fuel pump makes no change when pulling spark plug but engine dies when pulling plug wire on the fuel pump side. On the dead cylinder I removed the valve rocker cover and found both push rods bent with the upper intake aluminum one broke in two.
When I manually push on the intake valve it goes in with no restrictions. However when pushing in on the bottom exhaust valve it only opens a small amount and seems to hit something. Is this normal? (Just found the exhaust valve guide is restricting the valve movement). Rotating the crank by hand while placing a screw driver in the plug hole shows the piston moving up and down.
I straightened the exhaust pushrod and inserted it onto both valve tappets and each is moving when the crank is turned by hand. (I do not intend to reuse this pushrod)
Other than replacing a cam (compression release broke) in my Deere D105, I have never been inside one of these engines. So ..... what is going on inside with the crank or cam on this engine, if anything? Is it worth going further into the internals? It is on a Snapper Model 2690872 from 2011 and the tractor is in great shape.
Last notes, when I was given this tractor, BOTH cylinder heads were completely covered with mouse nests under their shrouds so I know the cylinders were probably overheating. Also, I just went back and checked and found the exhaust valve guide is what is limiting the movement of the valve. It has come out. I am hoping all that is necessary is cylinder head work.
Thank you in advance,
Lee A
Lee A
