I have a 22hp intek with about 650 hours on it. It wasn't running right. I toke it in to John Deere and they said the rods were bent. They replaced them and the new ones bent right away. They said it may be cam. I tore motor apart and cam looks fine to me. It's not bent and nothing looks damaged. When I move the things the rod connects to(rocker, valve) they don't give more resistance than I think there should be. I did clean the carb out a few months before this. One of the plugs looks dirtier than the other. I really don't know what I'm doing if that's not obvious any help would be appreciated.
