Briggs 21B807
michel28
Good morningI
blew my stiga enginemounted on a stiga chassisI found a Briggs and startron engineto place it insteadthe references of the current enginemodel 21B807 Type 0448 B1 Code 07122074I am looking for the diagram of the Briggs motor and if you could give me the departures and incoming wires - currently the Briggs motor has 2 wires at the output with a white connector
Thank you for your help
Sincerely
michel28
Good morningThank you for the linkI downloaded the pdf but on this one I don't see any possibility of connectionrecall of the briggs engine towards the steering wheel, starting keyGreetings
michel28
So red wire to battery or starter solenoid Black wire lightsBelow on the imageBlack wire to spoolGray carburetor wireNow I just have to connect the wires to the contactDo you have a diagram?Thank you for your helpGreetings
