I recently purchased a 33" Comet Hi Vac with the Briggs I/C 11HP engine (engine model 253702-0015-01). It ran pretty bad when i got it (bogged down under load) and i went through the carburetor and cleaned it up. Now it runs WIDE OPEN regardless of what i do. I believe that it has to be the governor that is causing my problem as it does not move when the engine is running.
I have followed the directions from Briggs on how to adjust the governor, but it won't work as the governor shaft will spin a full 360 over and over again and not stop like the directions say it should.
Is it worth tearing down to check on the governor internally or should I just look for a new engine.
I have never broken down a small engine, but definitely am not afraid to. How hard would it be.
A rebuild manual would definitely help me, but cant anything on the net for free for it.
Can anyone help me?
Can anyone help me?
