I have a near new ( 12 hours) Chinese mower with an intermittent but regular fault - it stops and won't start again - which results in a flat battery then when recharged starts first kick.
I have checked relays as best I can but I am suspicious of the oil cut-out switch as we live on a fairly steep block and the failures always coincide with the mower being on a slope. I am not saying it cuts out on the slope as that could easy be my wife's light weight triggering the seat cut out. But I think the failure to restart is related to the slope and the oil cut out. I tested my theory by adding 50 ml of oil and each time it started ok - but now the engine is over filled which I need to drain.
I have just wasted nearly an hour of my life on the totally useless B&S web site where I have tried ten times to enter the details to get a manual. Model 445577 Type 0139 Trim B1. It is an Intek 8230 724cc - given I know all that the web site refuses to identify the motor and offer me a manual.:thumbdown::thumbdown::thumbdown:
So I am really after a wiring diagram if possible as I say I believe the oil cut out switch is faulty and would like to disable it for testing purposes. I live 3 hours round trip from my nearest BS dealer and anyway I do not own a trailer big enough that can carry the mower so some testing in situ is called for. I have the parts manual and it describes "Wire Assembly Includes Green Oil Pressure Switch Wire" - but there is no green wire coming out of the engine and only 3 wires not 6 and they are red, grey and striped black. There are also a couple of wires coming out of CDI but they do not appear to be part of the general harness.
Please help
Please help
