Hi,
Ryobi rider, Kohler 19 hp Courage. It's been exhausting oil for a couple seasons now. I was mowing the other day and it was running a tad bit rough. Then, it shut down suddenly. Gas, air filter, etc. fine. Didn't hit anything. Will crank but zero ignition. Could the head gasket finally have gone and caused this? I'm not leery of replacing it, just curious if this is the likely cause before I start tearing it apart. Thank you for your time in advance.
