Blades
SeniorCitizen
What is a good ramp or lift to put my mower on when I am changing blades?
Two saw horses and a pickup tail gate works for me. A very convenient height to change blades, change oil, clean underside of deck, inspect belts, pto operation, grease etc. Using a little skill, I've removed wheels for repair while up there.
Ric
Try a MoJack $199.95 at Tractor Supply
Carscw
I just jack up the front or pull up on some ramps
Sent from my iPhone using LMF
Ric
To answer your question and assuming were talking about lifting a tractor or ZTR what you would use for a lift would or should depend on the size mower you're lifting and the tools you're using.
The Mojack Mower Lifts | Hand Trucks| Lift Accessories | Hand Truck Accessories | MoJack or the Turf Buddy Motorcycle lift and Snowmobile lift by J&S Jacks from J & S are IMO the safest way to go, they will give you the clearance or work area you need safely work under the mower with wrenches or impact tools without endangering yourself.
