Blades Blades for 72" Triton deck
Bremered
Exmark shows 7 different blades available. I normally use Oregon Gator Mulcher blades on my other equipment. Anybody have any recommendations?
biff.org
I am still new to my Exmark, so here is a stupid follow up. Has anyone put in rake blades with the fingers similar to those used on a push mower for spring de-thatching? Or is that just not common on a multi-blade deck?
Please do not attempt to do this, even if you find them. It will only shorten the life of your spindles, pulleys, belts and bearings.
