I have a series 16 Snapper Rear Engine Rider. When I pull back the lever to engage the blade everything works fine. Generally is isn't but a few moments before the mechanism releases and the blade is no longer engaged. It happens without hitting any object or even without getting into rough grass. I had that entire mechanism replaced a few years ago and it did better for a while, but now it is a constant aggravation plus that lever pops you on the back of the right leg when it releases! I'm wondering if there is any adjustment to this thing or whether there is a simple part the wears out that can be replaced. Any help will be much appreciated.
Ron
Ron
