Just got a used 33" Hi-vac.
Both the hi-lift blade and ninja blade that came with it were pretty worn, so I bought a new one of each, and will have the old ones sharpened and ready to change out when needed.
Put blade setting at highest position (6) and was amazed at how short it cut my grass!
Darn near scalped it in some spots.
I had been cutting it by hand at the second highest setting on a self-propelled, and just cut it 3 days prior.
So, here's what I tried:
-aired up tires to max 12 psi front, 22 psi rear
-checked to make sure blade was not upside down:smile: (not really possible with the channel built in to blade)
-adjusted blade level bracket by loosening the 3 bolts and pulling up to top setting
-put the 3 deck wheels to bottom hole. (although the wheels don't touch the ground at high setting, except on extreme dips or irregular spots)
Is it because of the design of the hi-lift blade?
Should I use the standard blade, and if so, will it have enough lift to bag clippings?
It looks like the ninja blade will cut higher, but haven't tried it yet.
Grass is mostly tall fescue, with a little Bermuda that snuck in somehow.
Thanks for any help.
