Belt tension spring position when installing
I have TB42 HYDRO that the blet drive tension spring came off. facing the front of the mower the spring is on the left side of the deck. I cant find a diagram showing how its installed does anyone have a picture.
Thanks
First thing you need to go back and delete your second post so people don't get confused. And then we will need the model number from under the seat since TB42 can cover several different models over several different years
