gregjo1948
- Nov 28, 2012
- 75
- 362
27 hp Kohler on an IS3100 Ferris Z. I have power to the center terminal of the regulator/rectifier.
Using a test light on the other two terminals, they brighten when the engine is reved up.
Testing the battery, with engine off, reads about 12.73 volts and running the engine it looses
volts. Why isn't the battery charging if it's charging at the regulator?(regulator/rectifier is new)
