My Scag is a repower with a 27hp briggs professional engine. No real problems other than the voltage regulator isn't hooked up to the battery, so it doesn't charge. Just want to confirm how it should be hooked up. It has a 3 wire regulator. Google has learned me that the two yellow wires go to the alternator, which they appear to be hooked up to already. I'm assuming that the red wire needs to be hooked to the battery to charge it? It's not hooked to anything right now. I can mow 3 or 4 times then the battery will get weak and I have to charge it. And if i use a sprayer or the lights I hooked up, it'll kill the battery pretty quick.
Any help would be great! Thanks!
