Greetings from the fine state of Missouri. I recently purchased a used Troy-Bilt garden tractor (mower). I am not sure what model it is called but I believe it is a B809H? It has a Briggs & Stratton 25 HP motor and 54" deck. It runs great except for one problem. The red battery light comes on when I engage the PTO, which I believe indicates that the system is NOT charging. Is it a bad switch or does this light indicate something else. When the PTO is disengaged the light goes out, so can I assume it is charging then? Thanks for your help.
