bigheaded5
- Jul 20, 2012
- 11
- 26
I just acquired a craftsman with a B&S 17 hp (Model:311707/Type:0132-E1). It starts EVERY time, runs smooth for a few minutes, then begins to sputter more and more and eventually dies. I thought it might be rings letting oil by (blue smoke with every sputter) but now notice oil blow by coming into the carb filter area through the vent tube. Im guessing this is a vacuum line from the crank case....could there be a clog in the system? Would much rather a clogged tube than to replace the rings as I was about to do this week.
bigheaded5@aol.com:confused2:
