Ariens snowblower carb
bmark0610
Hi everyone this is my first post!
Well let me first say that I am a new homeowner and I acclaimed a new to me snowblower around November last year. I had used it all winter and it wasn't running that great. It took many pulls get started and once started it would die. Then once it finally started I would have to turn the choke up very, very, very slow, so by the time it was ready to blow I was 10, 15 minutes in... Anyway how do I go about disassembling this and cleaning it? Any videos on how to fix my model? Please note this is very new to me.
AnthemBassMan
-YouTube is your friend. Tecumseh carb are easy to rebuild, you just have to make sure you clean every orifice. A rebuild kit with a new float should run you around $15 or so. I have a 22 year old mower that I rebuilt the carb four years ago, and she still fires up on the first pull. You'll just need to get the engine model # to make sure you get the correct kit...
L8R,
Matt
Along with the U-tube videos this procedure might help you. Kit number you will need is Tecumseh #631021B. After reassembly the initial adjustments are 1 1/2 turns out on the high speed mixture screw and 1 1/4 turns out on the idle mixture screw.
Needle and seat replacement
Remove the carb, and then remove the float bowl. Check the float bowl jet (which is the bowl screw) and make sure the jets both horizontal and vertical are clean and open. Tip the carb upside down and remove the float pin and float with needle attached. Look in the float needle passage and you should see the red or white float seat at the bottom of the passage. This is where a #5 crotchet hook would come in handy as you need to remove this seat. If you have no hook, but compressed air, you can blow through the fuel inlet and try to pop the seat out. Put your thumb over the passage to prevent the seat from flying who knows where. No air or hook try bending a stiff paper clip to dig the seat out.
I would either give the carb a good 24 hour soaking or have it ultrasonically cleaned at this time.
With the seat out clean the passage way with carb cleaner. Now you must find a drill bit slightly smaller than the passage way, to be used to press in the new seat. Apply a very, very small amount of a very light lube to the new seat. 3-1 oil or lighter, to help seat it better. Carefully insert the new seat in the passage way with the rings on the seat down toward the carb body. Slowly and carefully force the seat down with the back end of the drill bit. Once it is seated, check to see that it did not flip and the rings are up. *Next check to make sure that the float does not have any liquid in it. *If it does, replace. *If everything looks correct, attach the new needle to the float and install with the float pin centered. It everything is correct, the float should seat level to the carb body, when looking at it upside down. If everything looks good reattach the float bowl, making sure that both the bowl gasket and the nut gasket seal properly. Reinstall on the engine and test unit. Remember to have patience and take your time. Good luck, but I don't think you'll need it.
PS: *On the side of some Tecumseh carbs you will find a plastic cover. *Under this cover will be an idle jet. *Remove it and check to see that the jet is open both horizontally and vertically. *You should be able to push the old float needle wire through the vertical opening.
