ariens riding mower blades will not turn
jalute
belts are fine iam getting okay lights to activate blades. I flip switch no turning, yet light says blade is on... I have cleaned deck and all, no blockage.
Model numbers would help us help you, heat is jamming our ESP.
I would say the PTO clutch may be bad. You'll find a connector under the frame, check to see if you power here going to the clutch.
