I guess I have to rephrase my question. Does the seal leak between the seal and the crank or between the seal and the block. If it is the seal and block, you could try try putting thread lock between the seal and block when you install. Are you protecting the seal in anyway when you are installing. It is very easy to nick a new seal when installing. Try these steps. 1. Clean & dry block and crank fully. Use a Q-tip to check for nicks. 2. Apply lube to the area on the crank where the seal rests after installed. 3. Wrap protection over crank from the end to the block. You can use a piece of freezer bag cut and wrapped two layers. 4. Lubricate the inside of the new seal. 5. Slide new seal over the crank protection until it contacts the block. 6. Carefully tap the seal in place until it rests about 1/32" below the block face. Make sure you keep it square. 7. Pull out the protective material. 8. Slide the pulley on the shaft and make sure that the seal is in far enough that the pulley will not touch. I am assuming that you are installing this with the engine out of the unit. If you are leaving the engine in the unit, let it sit for at least one hour before attempting to run. This will allowing the seal to seat. Also, run the engine at low RPM's until the unit is warm, again to help the seal seat properly. Good Luck
