Another "Adding lights to my Raptor SD" thread
jaide
Hi All - I'm new to the forum. I've had my Raptor SD 54" about 6 months. I can't always cut the grass during sunlight hours. Instead of rushing to get the lawn done, I decided to add some lights. I have a question about the control panel for the light switch. I have the rectangular rocker switch. It feels like there is a cut-out to place the switch. Does the control panel come off to place the switch, or do I just cut the plastic and push the switch in? I'll post more pictures of the lights later. Thanks
Remove that screw on the left and lift up the panel. That should answer your question.
mhavanti
Jaide,
Here is a video that may help you out. It has strobing (flashing side and rear facing lights for mowing after dark as well as tail lights and headlights along with dash panel modifications you can use.
Hope it helps you out and if so, please subscribe, hit the like and notification buttons.
We also have a Hustler Enthusiasts group in Facebook if you'd like to take a look. https://www.facebook.com/groups/BigDogandHustlerTurfEquipmentEnthusiasts/
Hope the videos will be of great assistance to you.
Max
https://www.youtube.com/watch?v=nuaK6H6nbsg
