Welll, the smalll metal air-filter cup was used on dozens of models. Here are some of mine: 7221, 5083 The same carbs could also use a larger round air filter can with a snap-on cover. But cannot use the later rectangular ones.
If you want to get either one of these but the listing has ended, tell me and I will find another. If neither of the above parts is the one you need, please give me the part number of the needed part.
