the cover on my airfilter has 4 bolts you loosen to remove the cover.all but one bolt will unscrew . the one just turns but won't unscrew.how do i get it out ???? its a john deere 135. any idea's would be great. Thanks, rod
You will have to either pull OR push on it while trying to turn...Apparently the opposing threads are not caged and are turning with your bolt... sometimes pushing a fastener to the side will give it a chance to grab enough to remove...
Once you have it out you can then see what is needed to capture the threads & prevent a re-occurrence... Secure all 4 ... :smile:KennyV
Thanks kenny i tryed your idea and it worked.got it off.had to tinker with it and it finally come out.nothing broke. guess i wasn't holden my mouth right before. thanks again, rod
