pugaltitude said:What engine?
Known Ariens it will be kawasaki so possible starter solenoid.
Briggs and Stratton
pugaltitude said:Whats your model, type and code of engine.
The more details you provide the more help you will get.
pugaltitude said:Could be starter solenoid or could be decompressor on camshaft.
Take the spark plug out.
Does the engine turnover?
If it does could be decomp. If it does not it could be solenoid.
Also when you remove the spark plug, does any fluid come out?
Looks like starter solenoid. Voltage across coil of solenoid on key start. No click. Coil resistance good, solenoid stuck. Agree? Where is best place midwest for parts?
pugaltitude said:Yes sounds like solenoid.
Turn key to on position (not start). Make sure all safety switches are in normal position.
Jump the 2 big wires on solenoid (1 from battery and 1 from starter) with a pair of pliers.
Engine should turnover and start.
The reason for the fluid was in case your cylinder had filled up with petrol and engine had hydrauliced.
