hi i have a customer who has a craftsman riding mower it has a kohler 15hp on it . its a single cylinder . it was running fine but my customer said it wouldnt start so apon checking it out the battery was down to 5 volts so i jump started it i checked the voltage on a multi meter and it read 14 volts then started a count down ttill it gets to one volt while running then just shuts off . i took the cover off and discovered a mice nest and two dead mice . i looked at all the wires and cant find anything . i know something is wrong with the charging system though . i havent pulled the flywheel off yet . and tips suggestions ect would be greatly appreciated . thanks
