Adding lights to 2018 Toro Timecutter SS4225
JBR64
I want to add a few LED lights to my new Toro for nighttime use. Hook directly to battery or go off the ignition switch? Any ideas? Has anyone done this? Pictures?? Been looking on Superbrightleds.com
Should work fine as long as you watch your amp draw, don’t know how big you’re going. I would wire directly off the battery, with a rocker switch mounted near the ignition switch.
7394
Congrats on the new Toro !!
