does the shaft near the head on the stihl sf56 get hot
dbkw10 Forum Newbie Joined May 9, 2023 Threads 1 Messages 1 May 9, 2023 / A new stihl sf56 getting hot at end of shaft #1 does the shaft near the head on the stihl sf56 get hot
B bertsmobile1 Lawn Royalty Joined Nov 29, 2014 Threads 64 Messages 24,705 May 9, 2023 / A new stihl sf56 getting hot at end of shaft #2 If it has the strair shaft then ther is a bevel gear in there that will generate a lot of heat in use . There is a bolt down the elbow a bit to add 00 grade grease but do not add too much, just a little squeeze once a year will be fine .
