The recoil works fine problem is the gear only slides out about 1/2 way and if anything will just scrapes against the teeth on the fly wheel sometimes if you push it hard enough it will go all the way out and fully engage. If you take the recoil out it the gear pops all the way out no problem. Seems to be the only problem with the mower has new ignition module, plug, blade and air filter.
any suggestions, have tried everything I can think of.
