Check that your deck is clean underneath, grass build up can cause this.Also are your blades sharp and in good condition, there is a sharp, square leading edge and they aren't worn back .If all that checks out, I would check the forward pitch if the deck, on my dixie it seems to like about 1/8-1/4" forward pitch, sometimes the pitch will change due to hitting something or a just the chains stretching.You can set the mower on a flat surface, verify you tire pressure is correct in all 4 tires, and I use a 2x4 on its end and set the deck at around 3.5-4" and use the 2x4 as a measure see where it fits and how much clearance you have..sometimes you need to get a tape measure or small 6" ruler in the chute or under the deck on the highest height setting to get an actual measurement off the blades..when they are oriented front to rear.
