I have 2 tecs 1-5 h.p. and 1-6 h.p. Both are from the reclaim yard. The 6 took out the con rod but not thru the block. No other damage inside.
The 5 is h50 65389k 3355r with the extended cam shaft for reverse. Which I need for my Ariens snowblower, that has a cobbled up brigs on it.
The 6 is h60 75343j 1154d single shaft. The 6 has eletric start,which I want, but the 5 isn't drilled for bolts and doesn"t have ring gear on fly wheel.
Would it work to remove the parts off the 5 and install in the 6. Parts being the crank,
extended cam,conecting rod, piston and side sump. Reusing the 6 fly wheel, new gaskets and rings will be installed if this will work.
Thanks for any info on this project.
T.J. (Terry)
T.J. (Terry)
