Hey there,
I have one motor in my shop that has me stumped. Briggs 4 HP on a pressure washer mount. Found it at the dump and thinking maybe I should have left it there now haha.
Simply won't start. Will occasionally fart, but no steady running.
After you see the list you might wonder why I haven't thrown this in the lake, its because I'm high school small engines teacher and right now I have about 20 motors on the bench (and 30 students) in pieces and we try to go the extra mile to fix them. (truth be said most of engines that come in here have one foot in the grave already)
Here's what I have checked, any more ideas would be certainly welcome.
- 80 on compression
- Strong spark on plug
- Intake gasket good
- Breather gasket good
- Crankshaft and flywheel keyway tight
- Flywheel key in tact (new key)
- Timing inside on
- Both valves lapped
- Multiple carb change outs
- New diaphragm
- Air gap good (coil changed out)
Now I'm out of ideas:confused2:
Any thoughts?
Thanks
Rob
- 80 on compression
- Timing inside on
- New diaphragm
Any thoughts?
Thanks
Rob
