Can you run through the process to change the clutch cable and the brake cable on this model.
P popsljc Member Joined Jun 10, 2016 Threads 8 Messages 11 Aug 9, 2016 / 33" REAR ENGINE RIDER clutch cable #1 Can you run through the process to change the clutch cable and the brake cable on this model.
S shiftsuper175607 Lawn Addict Joined Sep 11, 2013 Threads 10 Messages 1,000 Aug 9, 2016 / 33" REAR ENGINE RIDER clutch cable #2 popsljc said: Can you run through the process to change the clutch cable and the brake cable on this model. Click to expand... Which model?
P popsljc Member Joined Jun 10, 2016 Threads 8 Messages 11 Aug 9, 2016 / 33" REAR ENGINE RIDER clutch cable #3 shiftsuper175607 said: Which model? Click to expand... SR 1433 MOD. # 3314518BVE
