ptetterton
- Aug 15, 2016
- Threads
- 1
- 5
Hello everyone i'm new to the group and was hoping to get some advise on my issue that I'm currently have with my Snapper Rear Engine Rider. The mower has 12.5 Briggs & Stratton, OHV, engine with electric start as well as manual start. The mower is approximate 7 years old so its a REAL Snapper, if you know what i mean. I was cutting the lawn last week and I ran out of gas. I refill the tank with the same gas that i had been using already and now it will not start, either by electric or manual. So i went to action to check out what was happening.. First i thought the unit was getting gas so i pushed it to a level area so the gas could flow down to the carb. Put the unit into chock and tried again, still would not start.. Next step, check the spark, i pulled the plug, connected my spark starter first to the coil wire and to ground.. I had a spark, so that was good, then i connected the spark tester to the plug with the coil wire installed as well and to ground..I had a spark. Tried starting again by electric start as well as manual.. again the mower would not start.. it would turn over but would not start.. So, i check all electrical connections could not fined anything wrong, then i bypassed the safety switches just in case.. and i had spark, I confirmed the switches were working by trying to start the unit without sitting on the seat and of course i had no spark, so i concluded the safety switches are working okay, so now that i have spark, compression, the only other thing i could thank of was the carb perhaps got trash from the fuel tank..so, my next step was to take the plug out again and spray carb fluid directly into the head, put everything back together again and tried to start, and again the unit would not start. Even though the unit would not turn over with the carb fluid I removed carb. anyways to check for signs of trash in the carb.. cleaned and reinstalled.. again the unit would not start.. so here i am asking for your suggestions.. I'm at a complete lost now.. PLEASE HELP..
