2012 Pioneer S Series 48" Rear Rim
Texas Blues
I need to replace one of the rear rims, and cannot believe how hard it is to find one for sale. Even used ones seem to be non existent. I have the part numbers of 116-3167 superseded to 116-5605. I have seen rear rims listed for the Pioneer S with a 60" deck, it's a different part number. It's still a 12 in rim just a slightly larger tire. My two questions are, is there a such thing as an exmark salvage yard or a good source for used parts? And last question is, have any of ya'll put the rim from the 60" on the 48", does it fit the hub and is the depth good so the tire does not rub on the frame? Maybe the newer Quest models have the same rim, I will have to look into that. Thanks! TB
Texas Blues
I did look up the newer Radius S series 48" models, and those rims might work. Still looking. TB
