Hello, Ok, maybe someone can answer this. I picked up a 2004 Kubota T1870 that had been stored for 2-3 years with 246 hours. It has the Kohler Twin 19 hp engine and has been well taken care of.
I installed new spark plugs, drained the fuel, rebuilt the carb and its only starting up with starting fluid. I’ve checked the fuel pump and its pumping. I cant seem to find any specs on the 1870 but was told by the lawn mower shop to set the jets at 1.5 turns. Is there something else I should check or do to get this guy up and running? Thanks
