I am reposting having posted to an incorrect forum or one where answers are less too plentiful. I Googled this as both Duramax and silver pro "problem" and am overwhelmed by how common this is for owners. The problem is I do not find authoritative answers. Some hit and miss reaming of jets that seems to fail more than work...ie. make the engine run rich. Just need some good honest knowledgeable input on how to get 1 of 2 I own dependable and then work on getting my other older pair working or junked out. THANKS! My initial post is below.
Model 10247 type/serial 200006838. Have to continuously prime it to keep it running and eventually it will run. This is one of 2 I have that don't want to keep running. I suspect a carb issue but I can not find a replacement carb only rather expensive parts to rebuild what I think is a problem. Also that flapper that governs needs a helper spring but for the life of me I can't find the PN. Was told once I need to get two springs to stop the run up and run down of the RPMs, a separate but aggravating issue.
My yard is about half steep hills and I need the 2 stroker to prevent burning up a motor. I am afraid now that they aren't made It is going to be an up hill battle, pun intended.
