2000 Grasshopper Kubota Engine
66vette
What is the difference between a Kubota WG750-B and WG750-E Engine. I can't find a Model number tag on my engine and I am hoping there is a physical difference that can be seen to advise me which one I have. The reason for asking that the E engine requires unleaded gas and the B requires standard automotive gas which I assume is non-unleaded.
If you want leaded you will need aviation gas , 100l I believe.
A 2000 year model engine should use unleaded gas. Leaded automotive gas got phased out in the '70s or early '80s. Use the non-ethanol gas. Pure-gas.org will tell you where to find it.
