2 Motors for Parts - Honda and Briggs
HBalboa984
I have two motors that have been laying around my shop for some time now and I just want to get rid of them. Below is a short decsription, pictures, and contact info. I can provide model numbers and all of that if you are interested. Would rather see somebody put them to use so taking best offers for everything.
First one is a Honda GXV530 twin parts motor. The motor threw a rod which cracked the casing and one of the cyinders. Only parts that are still useable is one cylinder and piston/rod, flywheel, housings, carb, exhaust, valvle parts, and the electronics. I have included a picture that shows everything that is included (ignore the cases).
Second one is a Briggs 13.5hp motor. The piston and rings need replacing, cylinder needs to be resleeved, head would need cleaning up or replacing. Still a lot of useable parts or it could be repaired.
I can be reached at hbalboa984@live.com or call/text (908) 894 4624. Thanks, Hayden.
