I have a 1989 MTD lawnmower that I purchased new in 1989 and has run great. The model is 119-422R - a Briggs and Stratton engine. Lately it won't start unless I remove the air filter (which is very clean). Once it is running, I can replace the air filter. If I try starting it with even just the air filter bolt in place, it won't start either. The choke flap moves freely. I'm guessing the bolt must block just enough air? Any ideas on what I need to do? Thank you. Richard.
