Hello i know this is a scooter question but i have a question for some of your experienced people out there. this is a 6 volt system here is the question its my understanding that the stator on older model scooters have a lighting coil with two parts. One for running the bike and the other for charging the battery unfortunatly one of the coils is ony producing .8 volts the other runs the bike great and the headlight is brite i tested the voltage regulator and it was putting out 6.5 volts consistantly my question is since i have all this extra power from the lighting coil can i run a wire from the regulator(one wire) to the rectifier and charge the battery this way. since the charging coil is about 30.00 and i would only have to run one wire if somebody knows please reply thank you briguyman.
