SHOOTERTPP
- Apr 16, 2014
- 2
- 16
I'm working on a 108 lawn tractor for a rancher friend of mine from out in west Texas.
Long story about how I came to be working on it, but so far I have replace the starter ( someone put the wrong one on it), replaced the flywheel (due to wrong starter), replace the point and condenser system with the magnetron system and rebuilt the carburetor. Now that it is running well, it was time to check out the rest of it.
The next problem I am now encountering is that when I engage the PTO by flipping the switch on the dash, the motor immediately dies.
I have disconnected the PTO clutch at the connector on the frame down by the clutch, but it still dies when the switch is flipped to the on position.
Here is the PTO switch.
Using a VOM, when the switch is in the off position, there is continuity between the center post and the upper right. Nothing else.
When the switch is on, there is continuity between the lower right and center and also between the two post on the left. The two circuits seem to be separate and do not appear to have any relationship to each other.
Anyone have a wiring schematic?
Any ideas where to go from here?
