Have had the same issues. It could be electrical, but I would try these fuel issues first [there cheaper, and work more times than not]. loosen fuel cap, replace fuel filter, blow air through fuel supply line [before filter] back into fuel tank, remove fuel shut off solenoid [replace with same thread bolt], replace fuel line between filter to pump, and from pump to carb with a clear fuel line [to be able to see fuel flow, and air bubbles], and finally clean,and flush carb. I would do one at a time [probably in this order], and when problem is solved replace solenoid, fuel line, ect. with approved parts. Good luck. Please let me know if any of these work. After this it's coils, flywheel clearances, rocker arm clearances, or even a over heated valve. Good luck Rick
