Martinomon
- Dec 29, 2016
- 1
- 6
I am putting a older opposed twin 18 HP engine in my Beck Boat....this is a direct prop shaft drive...these boats were Mfg`ed on Pine Island Fl in the 60`s -80`s for trolling ...slower the better ....my question is ...can I connect the 2 exhaust ports with galvanized pipe to a "T" and then straight up into a vertical pipe? I want to put a muffler just above the " T" fitting...then a aluminum up pipe that can be removed for going under low bridges. Since each cylinder fires alternately , will it cause any problems with getting rid of the exhaust? Thanks for any advice or thoughts ! Happy New Year !! David -Pine Island Fl.
