17.5 riding mower starting problem
ronws67
i have to jump it off sometimes it seem the compression is to high to turns fast enough to crank it sometimes spins great is there a relif on it can someone help me thanks
mechanic mark
Post tractor make, model & serial numbers as well as engine manufacturer and all numbers from engine: example B&S engine, model xxxxxx, type xxxx trim xx. It's called a compression release located on camshaft. You may need to adjust valves, compression release will not operate properly if valves are too loose. Key off, try rotating top of engine with both hands clockwise just past hard spot then try cranking with key.
