Cranking of the engine normally eliminates fuses and safety switches. You need to focus on actually checking for spark. and making sure you have fresh fuel. A little water in the carb can go a long ways.
Also if you have a fuel solenoid on the carb, make sure it clicks when you turn on the key.
